Here is where I am at with it. How is showing up to an event with 10 of the same bot ready to go considered an unfair advantage, when having a boat load of money, thus access to better materials & equipment is not?. If someone can afford to build 10 bot clones, and they all pass safety, how is that any different than being able to afford making 1 bot out of 3" billet titanium? Using the claim that having 10 of the same bots is an unfair advantage because they can afford it, doesn't hold up in my book. After all aren't we all looking for a competitive advantage? (batteries, material, design). Point is we're not about to create essentially a robot version of a salary cap are we?
I will agree that it should go against moral values to show up with 10 ready to go clones when you know that everyone else will be showing with 1 ready to go bot with spares to swap out as needed. But what if your intent is to have a disposable bot design (along with the disposable income you would need)
I personally do not see the harm in allowing people to have clones in the event their bot gets utterly destroyed. Where I would have an issue with it would be if they alternated the bots between fights as to reduce the wear and tear of the event.
In my opinion, this is a fine line topic that is hard to define.
Which actually raises another question. At what point during a rebuild process, mid-event, SHOULD a bot be required to go through safety again?
