Author Topic: Mutually Assured Destruction  (Read 37298 times)
Re: Mutually Assured Destruction
« Reply #30 on: March 21, 2015, 10:13:56 pm »
actually, reading your post again made me realize that what I changed won't fix your problem. Sorry.
« Reply #31 on: March 21, 2015, 11:49:39 pm »
Are you using a mixer? It could be miscalibration of the speed controllers, so one's seeing slightly further out of neutral than the other. If you recalibrate, but still have issues, you can try messing with your transmitter's settings, depending on what you're using.
I'm using this:
http://www.fingertechrobotics.com/proddetail.php?prod=hk-t6a
It's mixed using the file from the site:
http://www.fingertechrobotics.com/proddetail.php?prod=FS-L001
« Reply #32 on: March 23, 2015, 11:01:18 pm »
In other news, Slim Pickens works! All I needed to do was to recalibrate the ESCs whilst moving the trim on my transmitter. Now all it needs is a new wedge!
« Reply #33 on: March 23, 2015, 11:04:27 pm »
While moving the trim? Hmm, that's odd. How exactly did you do it?
« Reply #34 on: March 23, 2015, 11:10:56 pm »
On the store page for the TinyESC, it states:
"Is one motor faster than the other?: When calibrating the faster motor, also move the trim on the transmitter up (when you move the stick to the maximum) and down (when you move the stick to the minimum). Recenter the trim lever, center the stick and remove the calibrate jumper. This will limit the top speed of that motor. You may have to try different amounts of trim to get the motors to behave exactly the same."
« Reply #35 on: April 12, 2015, 11:12:06 pm »
Using bolts with lock nuts to support the wedge shaft for Thunder Child, I discovered this:
It'll be much more effective if I get flipped over. I'll probably make a new one out of thicker ti.
I also learned that someone damaged my lipo at Motorama. It was probably In The Margins.
« Last Edit: May 14, 2015, 11:16:30 pm by Infernaltank »
« Reply #36 on: June 19, 2015, 02:47:49 pm »
herp derp
spare bitties
just got the meat for the base today off to do that now
« Reply #37 on: June 19, 2015, 03:38:29 pm »
Looks good!
Headbanger142
« Reply #38 on: June 19, 2015, 04:15:32 pm »
Ripto Mode Activate...BOOP!
TEAM HEADBANGERS
Current Active Bots:
Mondo Bizarro (47-13)
Revy (6-5)
Motorama 2013 champion, Pennbots 2013 & 2014 champion, PA Bot Blast 2013, 2014 & 2015 Champion, Robogames 2015 Beetle Rumble Winner and MASS Destruction 2015 Champion
« Reply #39 on: June 19, 2015, 04:56:27 pm »
Nice to see VC back in action.
« Reply #40 on: June 25, 2015, 07:58:49 pm »
done
in the mail tomorrow
AlexH
  • wedge?
« Reply #41 on: June 25, 2015, 08:09:38 pm »
that bar is still begging to be a horizontal
« Reply #42 on: June 25, 2015, 08:15:12 pm »
Can it's wheels touch when it's on it's back with the blade spinning, or does it just count on flipping itself back over?
« Reply #43 on: June 25, 2015, 08:22:45 pm »
both
« Reply #44 on: June 25, 2015, 09:45:48 pm »
Good stuff.
Any news on FLCL? I've been wondering about how you were gonna do a pneumatic mantis for a while now.
