SPARC Forum
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
SMF - Just Installed!
Home
Help
Search
Login
Register
SPARC Forum
General
General Robotics Discussion
3mm be 1/8” shafts
« previous
next »
Print
Pages: [
1
Author
Topic: 3mm be 1/8” shafts (Read 2494 times)
LRC
Roboteer
3mm be 1/8” shafts
on:
September 03, 2019, 04:17:08 pm »
Any thoughts on drilling out 3mm wheel hubs to 1/8”?
After doing this, can your u still use them with 3mm shafts?
If so, is a shim needed and what material?
Thanks
Logged
Roboteer
Re: 3mm be 1/8” shafts
Reply #1 on:
September 03, 2019, 10:14:15 pm »
I'd advise against interchanging 3mm and 1/8" especially for hubs. You can certainly open a 3mm to hole 1/8", I'd recommend using a reamer so its a nice precise fit. Slop in the shaft/hub area is a recipe for wheels coming loose.
Logged
Print
Pages: [
1
« previous
next »
SPARC Forum
General
3mm be 1/8” shafts
