Author Topic: Snubbers used in shear  (Read 994 times)
« on: August 03, 2018, 01:34:17 pm »
I am curious about the use of snubbers to isolate different modules of a bot.  For example, bombshell and war hawk use many snubbers in the horizontal plane to isolate the main pod from the side pods of the bot.  It seems to work really well.  But it conflicts with the accepted explanation of snubbers, which is that they are great axially but horrible in shear.  For example, if you look at mcmaster, the shear rating is about 1/5 of the axial rating.
https://www.mcmaster.com/#9213k36/=1dzx3o0
If these bots took a vertical spinner hit it seems like the snubbers would shear off.  Is it just that there are so many of them being used that they can share the load enough to survive?  Is there something else going on that I am missing?   Thanks!
Re: Snubbers used in shear
« Reply #1 on: August 26, 2018, 01:37:32 am »
Many use wubbies in shear. Its obviously far from ideal, so the common answer is just use lots of them :P
