Author Topic: Revelation Robotics  (Read 107320 times)
RevRobots
Re: Revelation Robotics
« Reply #330 on: February 15, 2018, 01:20:55 pm »
Hey guys,
Wow, it's been a while since I've been on here, but I have a problem.
Whilst getting ready for Moto this year, the gremlins got to my Scorpion Mini ESC. The LED indicator light does not turn on, one of the chips gets very hot, and it gives no response. However, the BEC is working and the Rx works. All this makes me think that there is a short somewhere, but I have not found any. I swapped the ESC out for a spare that I had and it had the same problem, which makes me think that if there is a short, it's not in the ESC. Have any of you had this problem? I running a 11.1v Lipo, and 4 33.3 FingerTech motors.
Adam
Revelation Robotics
RevRobots
« Reply #331 on: February 15, 2018, 05:53:25 pm »
Regarding the previous post, in case I don't get this fixed in time, would I be able to buy an ESC from someone? I running 4 33.3's on a 11.1v Lipo. I would appreciate it if someone could bring one for me.
Adam
Revelation Robotics
« Reply #332 on: February 22, 2018, 08:26:38 pm »
Adam, did you ever get this sorted out? If two different controllers had the issue then you're probably right - somethings up in the wiring harness.
RevRobots
« Reply #333 on: June 27, 2018, 01:33:26 pm »
Hey guys,
What Milling service would you guys recommend? The parts i need done cannot be done with water jet.
Thanks,
Adam
Revelation Robotics
« Reply #334 on: July 17, 2018, 03:56:58 pm »
Team whyachi is easy, but local shops work too if you call around. I use one in Huntington pa called Reihart machine.
Zac
