Author Topic: Proposed Rule Changes for SPARC Robot Construction Specifications v1.1  (Read 3390 times)
SPARC
    • SPARC
This post will be used to track proposed changes to the SPARC Robot Construction Guidelines for v1.1.
Additions will be bolded, removed sections will be struck through.
Proposed Changes:
Alter rule 13.1 to read as follows:
13.1. Springs used in robots in the 12 lbs class or smaller and those loaded simply by the weight of the robot(eg. suspension systems) are excepted from the rules in this section. However safe operation and good engineering are always required.
