Hi, I'm Harry and I'm an alcoholic.
Been building robots for a while now. Will give a brief run down of some of the more recent, less cringey ones.
150g eggbeater antweight. Beater was made out of nitride hardened p20. Weighs about 70g or so. Never was very good because weight distribution was terrible and construction was pre mill and pretty poor.
This was my beetle, actually called Eggbeater because that got engraved on the beater for some reason. First version was pretty suck. 17mm grade 5 titanium beater powered by a stupid large HK outrunner. Sucked hella power and never drove properly
The second version was the first robot I made on my small hobby milling machine. Made out of some horrible blue plastic because n00b. It sucked still for a few reasons and was mostly overweight.
Third version was a good improvement. Still not particularly special. Can read the build in full here
http://bodgeitandhope.blogspot.co.uk/2014/09/beetlesbeetlesbeetles.htmlfailed at combat too.
https://www.youtube.com/watch?v=sOn9gR_ceBk&list=LLH7A1bjGSe3wc4Q0S0WUYrQ&index=11Red Wedding is my other beetle. It should make people cry like its namesake. Disc designed by Ellis Ware.
My main feather is an overhead bar spinner called Massacre. It failed pretty hard at its last event. The bar got bent, and the baseplate caved in. But it was a learning curve.
Link to the fight that really messed it up here: NSFW contains robogore and shattered dreams
https://www.youtube.com/watch?v=PYx52Z3oe5I The beater that hit it never quite worked the same though and ate its own bearings every fight after this.
If you are so inclined you can read its build starting here:
http://bodgeitandhope.blogspot.co.uk/2014/02/massacre-build-part-one.htmlNew version is underway.
Some parts layout and whatnot. This is what I'll probably document this build here when my robot marketplace order and lumps of titanium show up. Can give more spec on anything if anyone is interested.
Cheers all. Harry.
