Here is the list and discussion for upgrades we would like to do this year.
Numbered so we can easily refer to items.
1. Four TVs on top of the arena for displaying schedule, brackets, and highlight videos. [Travis has 1]
2. Double-stack the sponsor signs so we can fit the TVs up there. [Kurtis]
3. A 2ft metal post/stand that raises the spinning red light above the sponsor signs. [Travis]
4. A new control box that can run fights independently of a laptop (but can still take laptop inputs, etc).
5. New arena lights - 12V RGB LED strips that can be controlled via control box. Possibly individually addressable.
6. Audio system with cues from the control box
7. Run permanent ready/tap out cables inside frame with connectors on the end.
8. Replace inner lexan walls (maybe just the broken side? Or all?)
9. Repaint everything again because slushy salty January events are the devil. Get a paint shop to prep it properly!
10. New hazard heads, embiggen or harden the shafts (one is currently bent)
11. Hazard motors run from ESCs
12. New 12V battery (42Ah) and charger
13. Door lock interrupts so the control box can disable hazards and not start fights until locked.
14. Quick-release locking pins for doors [Test Travis's]
15. Ref controlled count-out trigger
16. Stainless steel floor? (Wouldn't need to be repainted as oftne)
17. 3 judging tablets/phones, tied into the laptop software.
18. Audio recordings of the announcer and inside arena (camera sound is not good)
Anything missing? New ideas are welcome!
Let's work out the logistics - what needs to get started right away, when people are available, etc. Starting with what needs to be done before the parade (August 8th)?
