Author Topic: uxcell 1000 rpm antweight motor  (Read 1283 times)
« on: November 07, 2016, 09:40:42 pm »
anyone worked with these motors?
looks like same thing as fingertech silver sparks but less $$
http://www.uxcell.com/1000rpm-rotary-speed-12v-high-torque-3mm-dia-shaft-magnetic-geared-motor-p-443845.html
Re: uxcell 1000 rpm antweight motor
« Reply #1 on: November 08, 2016, 03:02:20 pm »
I've worked with them.  Protect your wheels, and run foam wheels or else.  The power, weight and size are all very similar to the silver sparks.  I can't say for sure if the internals are the same, but I find them of similar (medium) durability.
« Reply #2 on: November 12, 2016, 10:47:56 pm »
Those look like the $3 eBay motors
« Reply #3 on: February 27, 2017, 10:54:44 pm »
Replying to an older thread, but I can guarantee that you won't find Silver Sparks anywhere but from FingerTech and its distributors.  They are custom made with heat-treated gears, the longer shaft, and the face-flush bushing (so you can easily mount with Bearing Blocks).
« Reply #4 on: April 11, 2017, 11:30:59 pm »
I run pololu micrometal motors in my ant, 30:1 MP with 22mm lego wheels is a great combo on 3s.
