June 23, 2018, 07:45:30 pm
Author Topic: Sharpening Weapon Screws  (Read 930 times)
iidrushii
« on: October 17, 2016, 01:02:52 pm »
Hello, friends.
I've heard that using a mill to take off the very top of the screw to make it's edge sharp works quite well. However, since I am without the luxuries of large and expensive mills, what would the best method be (in your opinion) for me to sharpen up my weapon screws? All I really own are some basic hand tools, a dremel, and an angle grinder.
Re: Sharpening Weapon Screws
« Reply #1 on: October 17, 2016, 06:38:30 pm »
I think your next best option would be the angle grinder and steady hands.  You only need to take off about .02" from the top.
iidrushii
« Reply #2 on: October 17, 2016, 09:42:15 pm »
Isn't that a bit overkill? Or will that just get the job done quicker than a dremel?
« Reply #3 on: October 18, 2016, 05:42:16 pm »
put a piece of sand paper on a flat table or lay down a file and then you can precisely rub off small amounts of material by pressing the screw head down into it.
« Reply #4 on: October 22, 2016, 09:07:45 pm »
Files don't cut screws so good, dremel or angle grinder is good. To hold them I'd take a nut and cut a slit in it, screw in the screw and clamp it in a vise so the split nut clamps the screw without damaging it.
« Reply #5 on: November 06, 2016, 11:36:30 am »
^ I'm loving that split nut idea for clamping screws.
iidrushii
« Reply #6 on: November 07, 2016, 12:38:30 pm »
the split screw idea would actually solve the problem I have with the screw slowly moving out of place when I grind it. Thanks for that suggestion :)
