Author Topic: Team Brain Damage  (Read 70480 times)
« Reply #390 on: February 10, 2019, 10:44:57 pm »
More progress this evening but no more spinups. I went on to a third implementation of the idler because the bearings cracked on the needle roller version with the aluminum ring. Now it's straight UHMW roller. At least if it jams it will just become a skid.
I also got a second roller hub finished up and made six spare roller tires. This way I can swap between fights in 2 minutes and then replace the tire on the second hub once the pressure is off. I doubt I'll need six fights worth, but I don't know. The top plates are installed too. I ended up cutting them from some random top plates I had in the 30 bin. They were probably from Tetanus, but I'm not sure. They were a perfect fit, just had to trim the point off and drill new holes. I'm happy with how they turned out.
Next up is making up a pair of spare drive motors and maybe replacing one of the skids that is worn down a bit from my bad bearing tests. At least I hope that's what did it. Oh, and theoretically I'll be reviving magneato.
« Reply #391 on: February 11, 2019, 12:02:54 am »
Any mods for Magneto or is time mainly for the new bot? I've really enjoyed watching the build grow up before Moto! The group on Facebook has been dominated recently by people finishing up their 30s and all I can say is that we are all in for a wild ride ;)
« Reply #392 on: February 11, 2019, 12:07:24 am »
I have no idea where Magneato stands. It will get whatever time I have leftover.. my focus is on the new bot.  Better to have one done than two not quite done
« Reply #393 on: February 11, 2019, 09:03:20 am »
Hey Zac,
What weight, Dia, and rpm is the shell going to be? trying to put together a reference list of feathers
« Reply #394 on: February 15, 2019, 10:17:24 pm »
Both are ready and thanks to a ton of work from a lot of people the arena is too. This is gonna be fun
« Reply #395 on: February 18, 2019, 06:52:05 pm »
Back from moto and slowly recovering. It was a great event and I had a lot of fun as usual. Our arena upgrades drammatically improved the safety of the arena and caused few problems with the competition. The biggest impact was probably the featherweight Final in which BEAM ended up outside of the combat surface behind the floating panels. Next year we'll probably make them full sheets to prevent this, but it sure was a big hit that caused it.
My fights were fairly satisfying. Hyperpolarized peformed very well in the first three fights, but then hit some kind of issue that prevented it from spinning in the last two. It's a shame - the weapon is a force to be reckoned with when it works. I still don't know what happened but I'll figure it out when I get caught up on all the crap I pushed off to make this happen.
The videos are here:
https://www.youtube.com/watch?v=vJyUmfECaJY&list=PLATw5d_vDtZlMzaKHjtvLq319q9mrYWgK
Thanks to all those who pitched in to make this happen. The NERC crew really works hard to pull off an event this big, and many people put in long hours to put up and tear down the arena on either end too. There were even some extra volunteers to do pit running, scheduling, announcing, and judging. You guys rock.
« Reply #396 on: February 20, 2019, 09:57:10 pm »
Excellent job on the new robot, it's very impressive in person as well as online. Can't wait to see it running at 100% next time around!
And thanks for reminding me about the forums, I'd forgotten you post all your build reports here. Very nice to see such detailed information on the construction of these bots.
« Reply #397 on: February 20, 2019, 10:08:19 pm »
I know facebook is all the rage, but I like having pinned discussions about specific things instead of sorting through the stream-of-a-hundred-conciousnesses flavor that Facebook promotes.
If there are only a couple of people who follow it I'll still try to keep doing it. I learned a lot from the Team Cosmos, Biohazard, and C2 Robotics build reports when I was getting started.
« Reply #398 on: February 21, 2019, 03:24:58 am »
I was very impressed with the performance of the new spinner in its first couple fights. I foresee an insect shell spinner being in my future... I also thought it was pretty cool how you have the bearing assembly on the shell, one thing you never really showed in the pic so far. Very clever and looks very durable.
After our discussion Sunday night I figured out how to embed pics here so I've started my team post as well here and will make an effort to maintain it in parallel to my facebook page.
« Reply #399 on: March 17, 2019, 03:36:48 pm »
The bearings on this shell were the same sorta setup as the last two with the needle roller in the center hub and a fixed center post.  I did make it much larger in this version to allow me to lower it. I'll probably rework the center post into a single steel "cup" for the next version. I think I can use standoffs for the retaining bolts and 3d print a plastic block to keep the standoffs from rotating when I put the shell retaining plate on and off. That will be better than the two-part setup I have now and shouldn't depend on Threecoil's old mild steel flywheel anymore :)  The bearing actually held up surprisingly ok - I thought it would be the first thing to fail.
I support a shell spinner in any class. It's hard to keep them working though. I finally got to take it apart this weekend and see why it didn't spin in the last two fights. I'm not 100% sure, but my theory is that the damaged lexan top plates from the Emulsifier fight allowed the retaining screws to dangle down into the base and jam on a hole in the mid plate. I have a big scratch and a dent in one of the air holes at the right distance from the center. I think when it jammed the weapon roller was ground into powder trying to drive the shell past the screw and then I couldn't spin anymore.
I replaced the roller for my last fight against Disko but I didn't remove the melted rubber from the underside of the shell. When I spun it up bits of that wrapped around the idler and jammed the shell up again, causing the new roller to annihilate itself like it's brother. This caused it to stop spinning again. These rollers were 80A hardness. They have a 90 and 90A hardness too that I'll try to see if I can get them to slip and wear a little less. I'll also need a better solution for the lexan top plates and will probably recut the midplate so there is no gap under the shell cover retaining screws in case it happens again.
I'm helping out as a mentor for a local team so they can get ready for the Rage in the Cage event at Bloomsburg High School in a couple weeks, and will be the referree at the Meadville Northwest PA NTMA regional on the same day as Rage in the Cage. Should be fun
« Reply #400 on: September 22, 2019, 09:05:03 pm »
Started on reworking Magneato for Franklin.  The design work is done, the laser cut parts should arrive from the shop on Monday or Tuesday, and now all I have to do is pull it together in the next two weeks.  Before I do work on the upgrades I will need to figure out why it stopped spinning at Moto earlier this year. That will likely be a job for tomorrow night.
For now, here is the beginning of the build/design log:
The basic idea is STOP GETTING STUCK.  I'm tired of having to wait to spin the thing back up when I end up upside down, and I want to be able to be more aggressive on the driving without worrying about flipping over. So I'm turning down the flywheel speed and adding an extra pair of wheels on top (with some fancy belt routing) which should hopefully keep the bot mobile no matter what orientation I'm in, even if the weapon dies. Let's face it, this is a complicated weapon that is not as reliable as I want - that shouldn't make me lose instantly.
To make the weight I'm switching back to a semi-standard rear-hinge layout instead of a four bar. I hate to see it go too, but that's the best I can do in a month's time.
https://tinyurl.com/MagneatoFI19
TeamAlreadyBroke
« Reply #401 on: September 23, 2019, 09:30:54 am »
I was hoping you were going to do another build thread before Franklin. I always enjoy reading through your thought process. I hope you are able to finish in time for the competition. We didn't change too much but will be running a new bot as well. I can't wait to go against a more aggressive Magneato! Good Luck!
- Dominic
« Reply #402 on: September 24, 2019, 10:07:44 pm »
I snuck in an hour of work tonight. Most of it was just unpacking parts and getting the work bench cleared off. The last 20 minutes or so was swapping to my backup DX6 because the primary one no longer senses the button presses on the left programming button, so I can no longer switch models or change settings. Magneato has different requirements than the last model I was on. I have a spare DX6 I bought a while back so I just bound it to a new rx and got the settings back in shape.
The last couple minutes was troubleshooting the weapon motor not spinning. I ran out of time for a definitive answer, but preliminary tests indicate it's not in the signal wiring, receiver, or microcontroller. It is likely a power connection problem between the phoenix and the motor. I'm hoping it's just a connector pulled out but will have to dig in more later. Hopefully tomorrow.
I got all of the shop drawings cut out at full scale yesterday, and all my machined parts are here now. Just gotta build it all this weekend :)
« Reply #403 on: September 24, 2019, 11:51:41 pm »
I think rear hinged will be more stable when flipping but time will tell. I gotta start posting some updates here too soon. I wish I could do franklin, but couldn't say no to Korea.
« Reply #404 on: September 26, 2019, 10:25:15 pm »
I worked on the flipper arm tonight. I need to remove and rework the break beam sensor cover plate because it makes the arm fit very snugly on the rear hinge pin. I can make a new one out of black plastic (which will natively stop the infrared beam) instead of the white plastic one I have now that has electrical tape wrapped around it.
I also need to add in the plastic block that goes across the flipper head and will serve as a velcro mount point so the arm will stick to the rear frame. This will hopefully help to prevent the "salute" the robot does as I turn sometimes because the gyroscopic precession causes a lateral force on the flywheel and pushes it into the clutch a little bit. This is why I started most of my matches with a ziptie holding the arm down - so the arm wouldn't do this salute until after the first flip. I'm hoping the velcro will work like an automatically resetting ziptie :)
Pictures:
https://imgur.com/a/SoVCA1z?
