The SPARC rules define controlled translational movement as "...being able to traverse in a manner such that the net movements of the robot are in a linear direction." This seems to be saying that as long as a robot is capable of moving in any direction (i.e. not just spinning in circles) that it should not be counted out. We ran into a situation at the last Kilobots event that has us a bit confused.
https://youtu.be/Mq98e7q1-5Q?t=31sIn the above fight, Killer Lotus spends about 20s or so on his back, moving ever-so-slightly due to the vibration his weapon was generating. We did not count him out at the time but reviewing the fight now we're wondering if we should have. There's no doubt that this movement is translational, the question is around whether or not it was "controlled."
Does controlled mean that the robot can start or stop the movement? In my opinion that's not good enough, but if one were to blindly follow what the rulebook says, it would probably qualify. Personally I think the "control" should refer to the direction of the movement, i.e. you're able to control the direction in which you're moving.
Just curious to see what everyone else's thoughts are!
