I have an idea and wanted to check if it is ok.
I think that is OK to do a non wheeled robot via sparc rules that uses 2 servos to control 2 legs. It is similar to a cam except that that it is not "continuous" motion -- because it is connected to a servo which only rotates ~120 degrees, you have to reload the cam yourself every time by moving the servo back to start position. Basically the leg pushes the bot forward when the servo goes one way, then the leg just drags back along the ground when the servo goes the other way to reload (you have a joint in the leg to let it drag the 1 way). So to walk you have to wiggle your controller stick back and forwards to toggle the servo alot. You can walk forwards (not backwards) and also turn by only using 1 of the 2 legs at a time. You might have other skids to the ground in order to balance better too so maybe its more like dragging than walking since its resting on these when the leg is dragging along.
I think this qualifies for the 2x weight allowable by sparc rules but not by robogames rules. Because robogames specifically says Linear actuator and a servo does not count as that. Am I right?
And also, has anyone else made walkers recently that follow either of these rule sets (curious what they did)?
Thanks!
Sparc rules
Non-wheeled: non-wheeled robots have no rolling elements in contact with
the floor and no continuous rolling or cam operated motion in contact with the
floor, either directly or via a linkage. Motion is “continuous” if continuous
operation of the drive motor(s) produces continuous motion of the robot.
Robogames rules
Walking: Walking robots are defined as those with linear-actuated legs which operate independent of each other. That is, any given leg must be able to move laterally and vertically with no cause and effect from another leg.
