Lucas, I have no idea what you are talking about, can you please be more specific. Last year, Plum Robotics made a new Still N Shock 2 with a new beater, 1/2 S7 hardened shaft to 52 Rockwell and like 7 or so inches long and have never had a shaft bend so bad that it is noticeable. They have bent on the ends slightly, but that is why we have backups. The only reason why Final Cuts shafts never bend is because of the length of there weapon. Its probably only 3 inches long, and not a lot of surface area for it to bend, where Still N Shock 2s shaft is twice the size in length and has a slight bend on the ends.
